Have a question about a Dropbox app or installation? Reach out to the Dropbox Community and get solutions, help, and advice from members.
Here are some of our most frequently asked questions. If you have a question that isn't covered by the FAQ's please create a new topic here. I see a "Couldn't start Dropbox" error on my Mac Seeing the "Couldn't start Dropbox" error on your Mac? Quick Resolution Confirm the Dropbox system extension & Keychain access are…
Hi everyone, I’m trying to set up Dropbox on File Provider with the Dropbox folder on an external drive, but setup always fails with Errno 513 (NSCocoaErrorDomain Code=513, “The file couldn’t be saved because you don’t have permission”). Choosing the default location on the internal drive works fine. Setup Mac mini, macOS…
I installed (and uninstalled, reinstalled—multiple times) and it keeps asking me to do two things: Sign out of my own device, which is somehow listed multiple times (I have basic plan) When installed, it says it can't connect to dropbox, and the error leads me to security settings (which I've checked over and over) and…
Uploading images or other files from Android phone to Dropbox via 'share to Dropbox Android app', the behavior used to be that the folder I navigated to and used for uploads would be persistent across sessions & days, unless I changed location on a subsequent upload. Now the upload target directory resets to the top level…
I have a personal work account and a work one. the Dropbox 'quick actions' for my work account are not showing on my Mac finder If anyone could help that would be greatly appreciated
Hello, I cannot sign in to the Dropbox app on my Samsung Galaxy S25 Ultra. It gets stuck on "Signing in, please wait..." and never finishes loading. I have already tried: - Uninstalling and reinstalling the app several times. - Clearing the app's cache and data. - Restarting my phone. - Signing in with Google and with my…
Hi, I'm on Windows with a Dropbox Basic account. Periodically, a task named "Dropbox Updater" keeps running and never seems to finish or stop. Related background: "Early releases" is OFF in my account settings on dropbox.com, but the desktop app keeps updating to beta (.3.) builds. Timeline: The app was on v277.3.4925…
I have a professional accout and when I go online it shows that, but when I download the app and it shows on my desktop by the date and time is shows I have basic and no files.
Why is the iPhone app suddenly always opening in the Home tab, instead of in the Files-tab where I left off? This is so … annoying, if you try to 'improve' the apps behavior, at least make the new way of working a setting that can be switched off, instead of forcing behavior to everyone that some people like, but others…
Note: This is not about the preview pane that appears when you tap on a file name. It is, however, about the persistent empty preview pane that appears each time you launch the app, regardless of where you are in Dropbox, before you tap on anything. This has made using the app in vertical (portrait) challenging—read:…
It looks like you're new here. Sign in or register to get started.
Learn how to use Dropbox and find answers to common questions in the Dropbox Help Centre.
Get the most out of Dropbox with free self-guided courses and live instructor-led sessions.
See available support options based on your plan including email, live chat and phone support.
