Get answers to your questions, connect with other Dropbox Community members like you, and discover how to get the most from Dropbox.
Do you have a question about Dropbox? Get answers here.
Learn more about Dropbox products with tips, tricks, and advice.
Explore the full potential of Dropbox with tips, tricks and discussions.
Have you got an idea for Dropbox? Share your idea here or vote on other ideas.
Whatever I search for, using the Search option bottom left of the Dropbox app, I only get a maximum of 4 matches. e.g. Search 'Archive' folder for pictures containing the word 'Sophie' of which there are 100s, I only see 4 results. The Mac desktop icon version works perfectly and shows them all. I cannot find any setting…
Will Dropbox still delete my files if I'm under my storage limit. I deleted files, and now I'm using 2.66 GB out of 2.75 GB. Does this mean my files are safe and the scheduled deletion has been canceled? Can someone from Dropbox please confirm? Thank you!
Thanks for using Dropbox! The desktop client is regularly updated with many improvements and fixes. Download Windows(Windows 10 or later) Standard Installer Offline Installer (32 Bit) Offline Installer (64 Bit) Offline Installer (ARM64) Enterprise Installer (32 Bit) Enterprise Installer (64 Bit) Enterprise Installer…
The Problem:When uploading multiple files via the web browser interface, users currently have no way to set a custom order or prioritize which file gets uploaded first in the queue. Real-Life Context & Use Case:As a filmmaker and long-time Dropbox user of 15 years, sending heavy footage directly through the browser is a…
Why is the iPhone app suddenly always opening in the Home tab, instead of in the Files-tab where I left off? This is so … annoying, if you try to 'improve' the apps behavior, at least make the new way of working a setting that can be switched off, instead of forcing behavior to everyone that some people like, but others…
If I pause for a certain time, it does not resume after this time. See screenshot - paused until 10:15 but it is already 10:18 (and leaving it much longer doesn't make it start) This used to work, and there was a previous report from 2025 ("Pause Sync" does not automatically restart on my Windows device. - Dropbox…
My Dropbox Basic account is over its storage limit because an approximately 4 GB backup from another PC is still taking up space. I have already unlinked that PC from my Dropbox account, but the backup remains and continues to count toward my storage quota. I am not able to delete it. How can I permanently delete this…
I know this right-click menu has been an issue recently, but my thing seems a little different. First: I am running Windows 11 pro with Dropbox 269.4.4231 My issue issue is that the right click menu keeps disappearing. I saw on a previous thread a direction to install the latest stable version of dropbox, which I did, and…
Hello Dropbox community, I use Dropbox Basic on my MacBook Air M1 My SanDisk external-drive backup contains Photos and Excel files. I want to keep my photos on my physical SanDisk drive and in my Mac Photos Library, but remove the cloud backup of Photos to free Dropbox storage. I need to retain my XL (Excel) files and…
Hey, I would love for it to be a shortened shared link!! It would be awesome to have a personalized link but if it's too much to ask, at least make it shorter! It looks AWEFUL when sharing documents to clients OR to my boss!! It's sooo bulky, makes everything look very unprofessional. I've seen a lot of posts about this,…
I am currently able to view many programming language files (such as Python and Java) directly in the mobile app or web interface of Dropbox. However Kotlin files are not supported despite being plaintext files like Python and Java files. Please can this support be added? It should be a very quick fix as they are just…
Hello Dropbox Team, When we generate a link in Dropbox, it is usually very long. I would appreciate it if you could provide an option to shorten the link or allow users to customize it by choosing their own preferred words instead of the default long URL. Currently, there are external websites that offer this feature, but…
Hi! I’d like to submit a formal suggestion for Dropbox to add Catalan as an interface language on the website, desktop app, and mobile app. As a Dropbox user, it would be very valuable to me and all Catalan speakers to be able to use the service in our language.
