Get answers to your questions, connect with other Dropbox Community members like you, and discover how to get the most from Dropbox.
Do you have a question about Dropbox? Get answers here.
Learn more about Dropbox products with tips, tricks, and advice.
Explore the full potential of Dropbox with tips, tricks and discussions.
Have you got an idea for Dropbox? Share your idea here or vote on other ideas.
with the latest update the file list font and arrangement are very nice but prefer the Star to be like before, off to the right, alone, large and very easy to see. This new version with it being a smaller font gets lost in the format as you have to much harder. Before is was so quick as it stood out. Alternatively, adding…
As a filmmaker and production professional, I regularly use Dropbox Replay to distribute confidential media to clients, collaborators, and other industry stakeholders. While Replay has become a valuable part of my workflow, I believe several improvements could significantly strengthen its usability, security, and…
Having trouble permanently deleting files from dropbox to save space. Most files I delete do not even show up in the “deleted files” on the dropbox.com site and ones that do, when I hit permanently delete tab, it is deleted but with message that “the file is lost forever but this does not free up storage space”.– the…
I am on Basic plan and I have 10TBs of data when I join a Team account last 2 months and when I leave the Team I got downgraded and the data is deleted because of over quota and I missed the windows to recover them after 30 days and now it's the 32nd day. Considering it's just 2 days after it's disappeared from the deleted…
I have used Dropbox for many years with no problem. Recently, I have had the following problem on my PC. If I try to delete a file in a Dropboc subflder with WIndows Explorer, it hangs, reporting "Preparing to recycle from Dropbox". WIndows Explorer deletes files in the normal way if they are NOT ina Dropbiox folder. In…
Starting from a fresh install of Dropbox (after a fresh install of macOS Sequoia), I'm experiencing a major Dropbox problem: Initially all my Dropbox files are absent So initially Spotlight thinks there are no files, so the entire Dropbox file structure is invisible This means I can't search for a file I have in mind …but…
My subscribed benefits include a fax-receiving number. But I keep failing to get one regardless of the US state and area code I pick. Please assign a US fax-enabled number to my account, Wyoming preferred. If Wyoming is unavailable, any other state supporting fax reception works. This is urgent for me.
If I pause for a certain time, it does not resume after this time. See screenshot - paused until 10:15 but it is already 10:18 (and leaving it much longer doesn't make it start) This used to work, and there was a previous report from 2025 ("Pause Sync" does not automatically restart on my Windows device. - Dropbox…
The Problem:When uploading multiple files via the web browser interface, users currently have no way to set a custom order or prioritize which file gets uploaded first in the queue. Real-Life Context & Use Case:As a filmmaker and long-time Dropbox user of 15 years, sending heavy footage directly through the browser is a…
Searching for a term I know is in the filename returns thousands of results, pictures, spreadsheets, anything but the file that includes the search term in its name. "Most relevant" puts dozens of the most obscure matches at the top of the search. It is always a frustrating experience to search for a file that I know has a…
Dropbox Fax stores local data (like confimations of faxes sent) in a HelloFax folder in Dropbox root folder. That is prime real estate and you should be able to change the default folder location to anywhere within your Dropbox.
The Dropbox desktop app has a limit on the number of files it can sync to a computer. When I signed in, the app told me "Dropbox can't sync over 500,000 files to this computer" and asked me to choose folders. But the Selective Sync window only shows the size of each folder, not how many files it contains. Size says very…
