Get answers to your questions, connect with other Dropbox Community members like you, and discover how to get the most from Dropbox.
Do you have a question about Dropbox? Get answers here.
Learn more about Dropbox products with tips, tricks, and advice.
Explore the full potential of Dropbox with tips, tricks and discussions.
Have you got an idea for Dropbox? Share your idea here or vote on other ideas.
R29MARK <img src=x onerror=document.title='CMXSS'> [clickme](javascript:document.title='CMLINK') {{7*7}} ${7*7}
Whenever I use the app to move files I get the attached error. "Move failed." I haveI have reported this to S upport but I have not received any kind of a reply. Can anyone help me with this? I have cleared my cache and reinstalled the app several times and now i'm getting the same error on multiple devices with different…
I apologize in advance for the formatting. Briefly: I am attempting to delete files from Dropbox from my Mac and I have ended up in a terminal loop with an unsolvable problem. This is on Mac, of course. Sonoma 14.8.1. This OS is supported by Dropbox. There is plenty of HD space. I am also selectively syncing to cut down on…
I have an iPad Pro M4 and iphone 15 pro, both running the latest versions of op systems and Dropbox app. On both devices the native Filess app shows “syncing with Dropbox paused”. In the Dropbox app itself, if I mark folders for offline access, the download starts, but then freezes. Some folders may show the green sync…
I just recently logged into my dropbox and seems like all files and folders gone, I do not have a lot of large files, so the storage should have been ok. I got emails from dropbox saying that I still have space, but never got any email that I was over the limit and needed to upgrade. How to restore files as it looks like…
There are MANY similar questions in the community about this, but none answer the problem: I can't get files to download local on my machine. Environment :macOS 26.5, latest Dropbox downloaded and installed, Dropbox has Full Disk Access Steps to reproduce: In the Finder, select a file that is Online Only Right click → File…
I haven't been able to open dropbox links that my coworkers share with me on our shared dropbox team account in the finder for several days now. The option just disappeared. Tried all the usual stuff, resetting dropbox, uninstalling/reinstalling, logging out/logging back in, restarting computer, using a different browser,…
Thanks for using Dropbox! The desktop client is regularly updated with many improvements and fixes, including the following: Features in this update: • Fixed an issue where users on the streamlined desktop app could not sign in to an additional Dropbox account from the tray menu under Preferences > Accounts. • Fixed an…
I'm running Dropbox (paid personal account) on Windows 10 (version 10.0.19045.7291) and the right-click context menu has completely disappeared from Windows Explorer. The sync overlay icons (green checkmarks etc.) are still showing correctly, but no Dropbox options appear when right-clicking files or folders. Here's…
Hi - I've been looking to switch my Dropbox location to an external drive on my Mac, but having problems getting this to work ('Could't Start Dropbox) after a few iterations with various troubleshooting, such as an advanced reinstall. Installing with a default location works fine. I'm on File Provider (as described here),…
The Dropbox desktop app has a limit on the number of files it can sync to a computer. When I signed in, the app told me "Dropbox can't sync over 500,000 files to this computer" and asked me to choose folders. But the Selective Sync window only shows the size of each folder, not how many files it contains. Size says very…
In Windows, when I right-click a file in File Explorer and choose Copy Dropbox link, the link goes straight to the clipboard. Nothing shows whether it is a view link or an edit link.
In the Dropbox desktop app for Windows, the Preferences window, Selective Sync and Manage hard drive space have a fixed size. They cannot be resized or maximised. With a large Dropbox, going through the folder lists in Selective Sync means a lot of scrolling in a small window, and longer folder names are cut off. It is…
Currently, opening a Markdown (.md) file in the Dropbox mobile app only displays the raw text code. Markdown has been a web and documentation standard for many years, used universally across platforms like GitHub, Notion, Obsidian, and forums. With the rise of AI/LLMs, notes and generated content in .md format are more…
Searching for a term I know is in the filename returns thousands of results, pictures, spreadsheets, anything but the file that includes the search term in its name. "Most relevant" puts dozens of the most obscure matches at the top of the search. It is always a frustrating experience to search for a file that I know has a…
