Get answers to your questions, connect with other Dropbox Community members like you, and discover how to get the most from Dropbox.
Do you have a question about Dropbox? Get answers here.
Learn more about Dropbox products with tips, tricks, and advice.
Explore the full potential of Dropbox with tips, tricks and discussions.
Have you got an idea for Dropbox? Share your idea here or vote on other ideas.
Thanks for using Dropbox! The desktop client is regularly updated with many improvements and fixes including the following: Fixed in this update: Fixed stale recents after signing out of an account. Fixed a File Provider crash that could occur after updating Dropbox on macOS 14. Improved reliability of encrypted-folder…
I just spent two hours annotating a PDF, in the iPad Dropbox app, both highlighter and handwritten (technically, the highlighter is handwritten, too). Now they’re gone. I’m sure I won’t get a reply before I need to use them, but for future reference and in case someone else has the same problem, are they just hidden? Is…
OK, I've searched for this problem and I don't see it in the community. Dropbox would not start after I did an "Update and restart" which I assume came from Windows. I'm on Windows 11 Home, version 25H2, installed on 5/19. See attached for the pop-up window and the file it's referring to. I have tried clearing the cache,…
641.1 gb of shared space is being used, but ive deleted/removed all access to all either sent or received shared files. this was over 36 hours ago. why is the 641.1 quota still showing on my account? How do i remove this shared element? Cheers!
Since this morning all the items in the Suggested for you section on the home page have pointed to the home page (https://www.dropbox.com/home#). It happens on two different computers and in different browsers.
my signing in to my Gmail account is terribly out of control I wish there was a sign in if you have a Gmail and give you the code to Gmail instead of your phone number.
Hi, I'm on Dropbox Basic. My plan page shows "Using 3.1 GB of 8.5 GB" with 5.4 GB unused (screenshot attached). The 8.5 GB is the 2 GB base plus bonus space. I've been invited to a shared folder that is 1 GB. When I try to add it I'm sent to the "out of storage" page and told to upgrade. What I've already checked: 1. The…
I occasionally copy around 5gb of files to my Dropbox for processing, maybe 100-200 files total. I pause Dropbox before doing this because otherwise my computer slows way down during the sync. Usually, all but about 70 get deleted before I unpause. When I unpause (usually after about a day), Dropbox usually has some…
Thanks for using Dropbox! The desktop client is regularly updated with many improvements and fixes. Download Windows(Windows 10 or later) Standard Installer Offline Installer (32 Bit) Offline Installer (64 Bit) Offline Installer (ARM64) Enterprise Installer (32 Bit) Enterprise Installer (64 Bit) Enterprise Installer…
I have a Dropbox. In it I store a variety of things. I store sensitive legal and tax documents. I store files I use at work. And I store ebooks and comic books I have purchased online. But sometimes, I have a computer where I don't want some of those files to go! For example, I have a tablet. I want to load my ebooks on…
This is product feedback. No reply needed. When a markup-edited HEIC photo from iPhone is uploaded to Dropbox using Upload Photos with JPG conversion, the upload date is used as the filename instead of the original capture date. Please improve this so the original capture date is used as the filename.
Hey, I would love for it to be a shortened shared link!! It would be awesome to have a personalized link but if it's too much to ask, at least make it shorter! It looks AWEFUL when sharing documents to clients OR to my boss!! It's sooo bulky, makes everything look very unprofessional. I've seen a lot of posts about this,…
Dear Dropbox, in Dropbox file preview on dropbox.com, please include visible timestamps when using “Copy transcript” or copying transcript text, not just the spoken text. Thanks a bunch!
