Hi all -- our small organization is a long-time Dropbox user. As such, our file structure predates when Dropbox added Team folders. Currently, all shared folders and each staffer's individual folder is nested under MY folder (as I'm the admin) since that's how it used to work.
I know I need to take the time to reorganize our file structure to work with team folders but had a few questions. (FYI we are currently grandfathered under an old Standard plan but I'm likely to change over to Business as it's the same price and has a few more features). I appreciate any feedback on the following questions.
- Can I move the existing folders out from under my folder and convert them into Teams folders, or do I have to create the equivalent Teams folder and manually move everything?
- Do people recommend having one main Team folder for a whole organization, and then create subfolders under it for different user groups, or do you recommend having a separate Team folder for each user group (for example, one team folder for all staff, one team folder for senior staff, or all nested together)?
- The "personal folder" that Dropbox Business creates -- as far as I can tell, unless I upgrade to Business Plus, I have no access to it as the admin. Which means if a staffer leaves, our organization loses anything they have stored in their personal folder? (Right now because I create a "personal" folder for them under My folder, we still retain access to those files when someone leaves). If I have no admin access, this makes me very uncomfortable as often people will save work files in their named user folder if it's something nobody else needs access to -- but it's still a work file and we want to retain it. People shouldn't be saving truly personal stuff on their work systems anyways. Is there any way to turn off the creation of this "personal folder" when you create a new user?
Thank you for any advice or suggestions - I appreciate them in advance.
