Hello Dropbox API team,
I built an app that loads and saves information from a single text file in Dropbox.
That app could be used from several devices, mobile and desktop, and therefore has to detect changes in Dropbox and update the app state as well as pushing changes to the dropbox file.
My research indicates that list_folder/longpoll would be the right way to approach this.
I implemented a simple longpoll where I would get the latest cursor, create a longpoll connection and listen to changes. I update the changes in the app if the revision in files_getmetadata is different to my last stored one, and restart the longpoll. I also restart longpoll if the request returns with "nochange". All that works fine.
But I'm having trouble designing a complete longpoll implementation which covers all edge cases. Here are some questions/examples:
-what is the best way to handle longpoll if an error is returned, either when getting the latest cursor or during the longpoll? An example would be a lack of internet connection. Currently, I postpone the next longpoll for 30 seconds (and in the case of a backoff response, for the seconds which are requested). Is that a good idea, or should I handle errors differently, perhaps depending on the error I get?
-supposed that 30 seconds delay is a good idea: In those 30 seconds (or it could be much longer, like on a plane), the file in Dropbox could have been changed by another client. If the longpoll resumes, the cursor has changed without the app knowing about it, right? Should I also store and watch the last cursor locally, so that I know something changed? Or use a different method?
-it gets more complicated when I save / push updates to that file in rapid succession (which I do): While the app is busy with handling a change from the longpoll, the next change could be on the way and I'm not sure it gets detected between the one longpoll exiting with a change response and the next longpoll not yet being established.
So my question is:
Is there a workflow or flowchart or an example for a complete implementation how to handle longpolling?
I found many examples for Dropbox longpoll and other longpolls in Java, Ruby or javascript (this is what I use), but they all just show how to listen for changes, they don't show the workflow (or whatever it's called) how to do longpolling right or complete.
So if you could point me to an implementation example or flowchart that details when to get the cursor, when to restart the longpoll, when to get metadata and perhaps when to restart the whole process: That would really help me a lot.
Thanks in advance for any reply,
l
Note: None of the tags really match, it's an API matter. The app is build with Cordova which is supposed to run on all the platforms I selected. I'm using the javascript SDK of Dropbox, but it doesn't matter to me which language is used in an answer.
