I get following error while trying to add the URI for webhook:
Error: SSL certificate problem: unable to get local issuer certificate
I can open the URL from browser and it works. What am I missing here?
Are you doing this at work? Perhaps behind a proxy server?
Hi Siddharth, I believe this is an issue where we may not be trusting one of the Certificate Authorities on your certificate.
We're checking if we can fix this on our side, but I can't say if/when that would be. Some workarounds for now that may help to get this working from your side:
- use http:// for your webhook URI instead of https:// - use a different SSL certificate
Apologies I don't have a better solution right now!
Hi Gregory,
Thanks for your response. Issue got resolved by combining the certificates into a .pem file as described in following link: https://www.digicert.com/ssl-support/pem-ssl-creation.htm
