Hi, Dropbox community,
I have a question, is there a posibility to add multiple automation for the same folder?
Hi @AndreiBarta, this happens because you've chosen an automation. You wouldn't be able to add more. You should be able to use multiple naming conventions on a folder, but not different automations.
As for editing the automation, you'd need to remove it, and then add the one you want.
Hi @AndreiBarta, how are you today?
To answer your automation question, no you shouldn't be able to. You can add multiple naming rules to the folder of your choice though.
I hope that clarifies!
Hi @Megan
When i want to add one more automation i have just edit automation option and in the edit window i can't even edit the automation
Hi,
for example is not possible to add these automations:
1. convert a file in pdf
2. rename the file as mm-dd-yy.pdf
to the same folder?
Morgan
Hey @Gualtieri, you are correct; only one automation can be added to a folder at this time.
