I need to try to take an exam on my computer, but the program won't allow me to with Dropbox running (dbxsvc). How do I disable it safely so I can take my test and then re-enable it after?
Hi @kkarisa, thanks for bringing this to our attention.
You can quit the Dropbox desktop application entirely, which will exit the program and stop it from syncing.
Once you're done with the exam, you and start it up again like a normal program on your machine.
Keep me updated with any progress!
@kkarisa wrote:The Dropbox button vanished from the Taskbar, but the exam center dialog box that told me to close the program still detected it as running.
Go into Task Manager and find the remaining Dropbox tasks, right-click on each one and select End task.
dbxsvc just comes right back.
Hey @martinhawley, thanks for the nudge here.
Can you give us some more info or send us some screenshots explaining the issue you're having?
