Dear Dropbox Community,
I have a question regarding an issue some of my customers are facing with Dropbox. While many of them are very satisfied with Dropbox’s features, a few have encountered a specific problem when using Adobe InDesign or Illustrator on Mac.
The issue arises when they import and use various elements from multiple folders. Initially, this works fine, but problems occur when another team member tries to work on the same file later. The links to the files are lost, and they have to be manually recreated, which is both tedious and time-consuming.
It appears that the problem stems from each user having a unique home folder name. Dropbox, unable to locate the identical home folder name, breaks the links.
The Dropbox support team suggested two possible solutions:
1. Ensure each computer has a home folder with the same name.
2. Place the Dropbox folder at a higher level than the home folder (such as Macintosh HD or the top level of the user folder). However, I have tried this, and the Dropbox app refuses to create a folder at that level.
Has anyone else experienced this issue? If so, what solutions have you found effective?
Thank you in advance for your valuable help.
