I was able to check the Up/Download speed of syncing files via the Dropbox app, or by moving the mouse over the Dropbox Task Bar icon. (Windows 11). Has this feature been removed ? See screen shot below.
Hi there @NB141 - thanks for posting on our Community!
It seems that the version of the app is a little outdated. Could you update to the latest version of the app from this page directly and let me know how it goes?
Thanks!
@Walter It worked ... I'm guessing a reinstall sorted a Windows issue as the Dropbox notification box wasn't changing in size depending on the file name length, hence speed text was missing... anyway all sorted. Thank you!
