MacOS 12.6.9
Dropbox 186.4.6207
DB icon in menu bar constantly showing sync.
Quit DB.
Restarted DB, now icon is grey and shows "Connecting Components."
I read through this post: https://www.dropboxforum.com/t5/Apps-and-Installations/Dropbox-app-stuck-on-Connecting-Components/td-p/713477
Does not apply to my situation, I am not using a beta, I am not running Ventura, no version in ~/Library/Application Support.
I am also using DB 186.4.6207 on another computer running MacOS 10.14.8 with no issues.
What steps are needed to fix this ?
Thank you.
