Hello!I am using windows 10Can i replace the hard drave letter with folder drop box1. Will my files be saved ?
2. Dropbox will be updated ?
Hi @evgenbaranenko, thanks for messaging the Community!
In Windows, it isn't possible to rename a drive letter to a word. Only the 'descriptive name' would change, which according to your screenshot is 'BASE'.
Renaming that wouldn't affect your Dropbox folder since the drive would still be located on e:.
If you need any further assistance, please let me know!
