Wondering if there is a way to set the default drag + drop behavior to match all other behavior on macOS: copy and paste, rather than the Dropbox default of cut and paste.
In other words: when I drag final exports of a photo project from the exports folder on my hard drive to the folder in Dropbox so I can share it with a client, by default, Dropbox deletes it on my hard drive. But if I click and drag the file to any other folder that is not Dropbox, including external hard drives, SD cards, other cloud services (Box), the files are copied to the new location and preserved in the original Finder location.
Is there a way to change this to match the rest of the operating system's behavior?
System info:
Macbook Pro 16" 2019
macOS 10.15.7
