Hi ! It's been 2 weeks (I think) that dropbox doesn't sync when any of my VPN server are off.
I don't use any weird VPN client, I just set a regular VPN, in the Win10 settings panel. Adding the VPN server adress, and done : https://image.ibb.co/k2k2Zf/Capture.png
I'm pretty sure it has worked for more than a year : The dropbox sync was OK wherever any VPN was ON or OFF.
The strange thing is... I tried to re-install the dropbox client, and the same thing happen with dropboxinstaller.exe cannot have access to internet if no VPN connexion is active !
Every other internet apps work normally. Firefox, Windows, Steam... Even my Nextcloud desktop client doen't care if a VPN is turned ON or OFF. It just finds its way to the internet.
Anyone has the same issue ?
