Question: "I'm working on integrating Dropbox into my web application using the Dropbox Drop-ins library. Currently, I'm able to load a folder from Dropbox using the Chooser, but I'm facing an issue. When a user selects a file from the folder, it opens in a new tab with the Dropbox website. However, I want the selected file to open within the same iframe where the folder is loaded. How can I achieve this behavior?"
Context: I'm using the Dropbox Drop-ins library to allow users to select files from their Dropbox account and interact with them within my web application. While the initial folder selection works smoothly, I'm struggling to handle file selection events and load the selected file within the same iframe.
Desired Outcome: I want to ensure a seamless user experience where selected files from Dropbox open within the same iframe, avoiding the need for users to navigate away from my application.
