Hi,
I am trying to sync data from a raspberry pi to a dropbox app, so that I can access the data remotely in real time (e.g. it updates every 10 mins). I created a flow in Node Red to do this, using the dropbox out node - and put in the access token from my dropbox app. This worked well, however, the access token expired after a few hours. From researching, I see that dropbox is now only generating short term access tokens. However, for my data collection I require long term access.
1. Would generating a refresh token solve this problem?
2. If so, how do I generate a refresh token? I have downloaded python and python SDK, and tried to follow the documentation, but I am confused and cannot get it to work.
I would really appreciate any help on the above, or any other ideas you may have as to how to sync this data!
Many thanks,
Laura
