Hi,
(Sorry I first posted this as a reply to this "solved" topic, which was a bad idea because it's mostly unrelated)
I'm developing a "native" app (called Ginj), and started Dropbox integration a few weeks ago.
I first used Dropbox's Java API for authorization, using PKCE and "copy/paste" from browser to app, and it seemed to work pretty well but now it seems I'm forced to re-authorize regularly.
After checking the received tokens, they are now indeed short-lived "sl-..." tokens, so I decided to call the REST OAuth API myself to see if I could implement the updated flow, and also get rid of the copy/paste step.
I think I'm nearly done, but when exchanging the received code for tokens, the response I'm getting contains an "access_token", but no "refresh_token" and no "expires_in".
Now the access token seems to be "long lived" again, but I'm reading non-expiring tokens are getting deprecated, so I'd rather switch to the refresh logic while I'm at it...
How can I get a refresh_token ?
KR,
Vicne
