Hi,
Back in May, I successfully installed the Dropbox API v2 SDK for Objective C, version 3.1.0, for use with a Mac app, using the Carthage system
Now, trying to update the SDK to the latest version (which I belive is 3.2.0), I am running an issue. The problem not only occurs when trying to update the existing SDK but also when trying to install the new SDK cleanly.
Specifically:
1. I create a directory with a Cartfile with the following contents:
# ObjectiveDropboxOfficial
github "https://github.com/dropbox/dropbox-sdk-obj-c" ~> 3.2.0
2. I run the command:
carthage update --platform Mac
This results in the following terminal output:
*** Fetching dropbox-sdk-obj-c
*** Checking out dropbox-sdk-obj-c at "3.2.0"
*** xcodebuild output can be found in /var/folders/9j/dj_qfpgn77l_xcj2dvtpql3c0000gn/T/carthage-xcodebuild.ufrALJ.log
*** Building scheme "ObjectiveDropboxOfficial macOS" in ObjectiveDropboxOfficial.xcodeproj
Build Failed
Task failed with exit code 65:
/usr/bin/xcrun xcodebuild -project /Users/phoyer/work/Revisions.wc/branches/Test/Carthage/Checkouts/dropbox-sdk-obj-c/Source/ObjectiveDropboxOfficial/ObjectiveDropboxOfficial.xcodeproj -scheme ObjectiveDropboxOfficial\ macOS -configuration Release -derivedDataPath /Users/phoyer/Library/Caches/org.carthage.CarthageKit/DerivedData/dropbox-sdk-obj-c/3.2.0 ONLY_ACTIVE_ARCH=NO CODE_SIGNING_REQUIRED=NO CODE_SIGN_IDENTITY= CARTHAGE=YES clean build (launched in /Users/phoyer/work/Revisions.wc/branches/Test/Carthage/Checkouts/dropbox-sdk-obj-c)
This usually indicates that project itself failed to compile. Please check the xcodebuild log for more details: /var/folders/9j/dj_qfpgn77l_xcj2dvtpql3c0000gn/T/carthage-xcodebuild.ufrALJ.log
Looking at that log, it seems the relevant error is:
/Users/phoyer/work/Revisions.wc/branches/Test/Carthage/Checkouts/dropbox-sdk-obj-c/Source/ObjectiveDropboxOfficial/Shared/Generated/Routes/DBTEAMTeamAuthRoute
s.m:131:9: fatal error: 'DBTEAMNamespaceMetadata.h' file not found
#import "DBTEAMNamespaceMetadata.h"
1 error generated.
Any idea of why this happens, or how to solve it? Any help would be much appreciated!
Thanks!
Patrik
